Thanks for the info on head dowels that should move it enough just barely touching now.I take it the ultrdyne 640 is a good enough cam selection to make it worthwhile.Block is decked .020 and if i deck head additional .080-.100 moveing heads up ought to help with manifold alighnment even though im sure it will still require alot of milling .
