Quote: Tire stores around Columbus, OH don't have/can't get them in a 235/60 15 (the standard factory replacement size). I called BFG & was told that they were depleting the inventory & will be producing another batch in June. I griped, but was told that the Radial T/A is just not a common tire. Really? Did the musclecar world change & I missed it?
What tires are you guys using?
Even if your running them on an E body, switch over to 245's,...and run the GoodYear Eagle GT II's..get'em at Summit racing.com,...I ran the BFG's for years, you'll find the Goodyear a much better tire IMO
