get a shorter oil filter?
How was the BB radiator lower bung arranged?
do some quick measureing/eyeballing & if a shorter filter would give you room to run the hose that'd b the fastest solution. BB's did come w the hose on both sides so not sure how that worked as I'm just getting back into BB's. Might b when they switched the hose they switched the nipple. holler how it turns out & the sol
