The two? issues you have here ......
Severe burned-oil-deposits on the back of the valves and on the stems is more likely loose guides. The cam lobes ? ..... I have made it a practice to mark each lifter on the top with a dab of white paint ...so it can be EZily observed if there is proper lifter rotation.
