Re: No Power at Yellow Wire
[Re: anlauto]
#992873
05/15/11 07:21 PM
05/15/11 07:21 PM
Posts: 18,157 Mass
DAYCLONA
Mass
This car has got ALL new wiring front to back.
I still have no brake lights or reverse lights...I plan to check the reverse light switch, the next time the car is in the air, but I have no idea on the brake lights yet...
I've never in all my years had so many issues...
To make matters worse, I'm not too familiar with B Bodies...
B body brake lights, or lack of them,...are a common problem esp on 70's......make sure your grounds located thru-out the car are GOOD, check with a meter for continuity,......have you got turn signals?,.....is the column turnsignal switch/harness new?
Reverse lights are pretty straight forward,......was this car originally automatic?
If original 4 spd, and the back-up harness is new, and checked for continuity,...I'd start with the switch on the tranny, just put the car in reverse and check for continity on the 2 blade ends on the switch,.....I find that some of the repro 4 spd switch plungers don't make contact with the reverse detent,....even if you have to remove the switch to check continuity by manually depressing it, do so, just to eliminate the switch,....so no more chasing electrical ghosts
Mike
