No, 5 flats is what is is raced at...........race ready status
Normally you scale a car with 0 pre-load then add
in 20# or so then hit the track to see what it does
then add or subtract to correct... but the weights
looked close...if you add alot of pre-load it can
up-set the car on decell on the top end when you nose over
