gettin there.....
![](https://lh3.googleusercontent.com/_jPBQzCubAx0/TcrK61BZEvI/AAAAAAAABjE/pW4NQhjetXs/s800/fury_eng_inprog.jpg)
![](https://lh4.googleusercontent.com/_jPBQzCubAx0/Tc8EOQJbwyI/AAAAAAAABlY/1mM8M97B7O0/s800/2011-05-14_16-34-04_514.jpg)
Hot sides are all done and ready to be finish welded, going to 'let' Shaun do that so that it looks decent and stays together.
Cold side is almost done, need to do 1 more 3" bend into the TB
![](https://lh5.googleusercontent.com/_jPBQzCubAx0/TdGq4sj5eiI/AAAAAAAABl8/vTzBiWHm6v4/s800/2011-05-16_17-28-49_998.jpg)
![](https://lh3.googleusercontent.com/_jPBQzCubAx0/TdGpwi1jNdI/AAAAAAAABl0/tj6cS6W8Ko8/s800/2011-05-16_17-29-09_600.jpg)
![](https://lh6.googleusercontent.com/_jPBQzCubAx0/TdGl3D_4nqI/AAAAAAAABls/EPulh4i5gaI/s800/2011-05-16_17-28-19_524.jpg)
Might try to find another turbocoupe outlet hose to put over the right pipe to make it look more symmetrical, will paint them all black as well. Got the oil feeds in and the drains mocked up. Still working on what to do with the alt, need to find some 1/4" stock to drop it and not worry about it deflecting. I'm ready to be done working on it and driving it instead :2thumbs:
