I would be looking at 10.5 PV's to start with if it is a healthy stock 318. Hopefully you have carb's with removable air bleeds because you will most likely need to lean out the idle circuit a ton with two carbs...unless the massive plenum area makes up for it. Who knows, with some tuning it might run fine.
