You're kicking back a percentage of your profit on this job to the forum for doing your background work for you, right?
The switch goes in that tab that's welded along the driver's side rail. It's a plunger like the door switches are, but I'mm not sure if they're the same or not.
The light goes under the package tray.
Everybody makes fun of a hillbilly until they need something fixed
