Has anyone experienced this type of ignition problem?
No I have not & I'm gonna guess an open somewhere (but where is the Q) rather than the ECU (or the coil or pickup)EDIT next time I'd check voltages without bumping any wires/connections as you dont want to disturb the open when it's open assuming that that's it. Holler what it turns out to b
