If it is drilled for pushrod oiling then make a restricter in the driverside rear galley plug,the orfice should be aprox..050 to .070.Do not put anything in the passenger side galley.The best way is to restrict it at the lifter or pushrod
I just spoke to BIGTIME earlier I sent him a picture of what is in my 604" motor and all the emasurements. He made one and reported back it worked perfectly. I had also sent it to Bg for his evaluation of it. .
home of the
Sox and Martin Hemi Duster
