I would do it before--oil won't go bad sitting in an oil pan all winter. and it gets rid of exhaust contaminated oil.
worst that will happen is you get some moisture/condensation build up over the freeze and thaw of winter, but the first time you drive it and get everything good and hot, that moisture will evaporate out.
**Photobucket sucks**
