They're a very seldom used metric size, but don't remember which. I checked with a local aircraft supply place where I get all my normal AN fittings.
I was just looking for caps for them as I'm just running the lines to an auxilery cooler.
I'm going to end up cutting off the end of the tubing portion to get it out and have the hole in the fitting tigged over to create a cap.
