Getting close to finishing up my Super low buck 318! Got the heads, intake cam and covers on. Just need finish up fuel lines, and hoses. Then put the radiator back in and then done.
Anyways what do you guys think this combo will do, 1/4 mile?
The engine is a .030 over 318
hypereutectic flatop pistons, compression comes out to 8.9 to 1
1.88 1.60 916 j heads with a good valve job
Engle cam 260 adv int &ext 216 at .050 in & exst .456 lift 113 lc installed on a 108 ic.
360 intake milled divider and smoothed plenum
750 holley vacuum secondary
1 5/8 headers. 2.5" exhaust
125 nitrous shot
Stock 904 and hi stall factory converter stalled around 2200 rpm
3.55 SG 8 3/4
26" tall drag radials
I have less than $200 into this engine, most of the parts are peices that have been given to me or, traded for. Not worried about blowing it up since the 360 will be going into it in a couple months
The car is a 69 barracuda 3400lbs
