How light is your bobweight?
I had a 5140 material MP 3.75 stroker crank, it was basically a resto HEMI crank with the mains cut to fit a low deck , the counterweights were HEMI HUGE , crank wouldn't sit in the main saddles. I had it cut down to 7.200 and it only required 2 holes, one at each end of the crank, to balance. My bob weight was around/under 2400 if I remember correctly.
