Quote: 255/60R15's will fit on the front. The wheel offset is the main concern. If you use 15x7 with a 4.25 rear spacing you should be fine.
That what's on the front of this GTX I used to own. It had 275/60r15'son the rear.
Sorry to hijack the post. A guy is coming over this weekend to perhaps buy a set of 15x8 AR200S's with 245/50s on them. The BS is 3-3/4". His car is a '68 GTX. Is he gonna have a problem? The car is same as OP's Q, so I figured it was a legit question...
