I am ASSuming the specs are the same but not 100% positive. W your meter on it & you wiggle the wires/bump the coil you do not lose continuity right? though a coil (of any type) can test good cold then act up when hot. Lean burn or an electronic spark control (ESC) ign? What yr?
