The turbos are the cheap part. You going to flip the mani's or make custom headers?
You can't flip B/RB manifolds. They will block the spark plug holes. If you put them on the wrong side the steering box and driver's engine mount are in the way.
We are brothers and sisters doing time on the planet for better or worse. I'll take the better, if you don't mind.
- Stu Harmon
