Anyone use Stage V Replacement heads with larger head studs ..?
Can you just drill the heads for larger studs, or do you not need to?
help appreciated!?!..
an honest answer is hard to give without knowing the application. on blown alky you need 9/16 on N/A street studs are a good upgrade in the same stock size or stock bolts will work also
home of the
Sox and Martin Hemi Duster
