well, fall 2009 it wint out on me & I had it rebuilt by my Mechanic with new disc, new, stock none lock up TC & some other stock parts that I had to order, but I had to get the Front Ring Gear from a good 904 6cl trans that I got, because the place I got the parts from did not have it & the VB should be Stock because it was never changed out. The problem is that it don't hold back when you pull it down in second gear & my Mechanic tould me its eather kickdown band needs readjusting or when it went out on me the metal going in the VB may have scratch it & he missed that when he had it apart, so if it is the VB then, I'm just going to use the one from my 6cl 904.
