Looking to cut up a stock k member I've got laying around and add a front mounted rack and do some lightening. everyone says if you swap spindles side to side it will throw the steering axis off....but what if you just swapped ball joints and installed the rack so it is at the same angle as it would be in a rear steer configuration? I'm having trouble understanding why it wouldn't work if your rack angle is the same as the original rear steer
Maybe I haven't had it simplified enough lol
