took my old 440 trw 2295 slugs,threw in new set eagle rods milled the domes off.065 in the hole,452 heads fresh valve job pc seals ss 2.14-1.81 valves,500sh hyd cam ebay waistegate blowoff valve,series 60 detroit disel garrett turbo,750 holley I modded for blow thru,used hat,adding some methanal for cooling,any guesses on power 8 psi or more,pulling my indy headed 512 out to play with this always wanted http://www.youtube.com/watch?v=AsU9RnmKdkgturbo
[b] [color:"red"] 67 GTX 440 twin turbo efi 10.72 128 3900lb 3.55
