just wondering ( and not wanting to highjack the trhead but )
why not to FIX the frames or the area what makes to NEED those offset bushings ?
In the original poster case, he is actually not using them for thier original intended purpose. For increased postive caster you DO NOT use/follow the instruction in the kit.
You follow these modified instructions....
