I am switching from Power to Manual Brakes on a 70 Cuda. Disks up front Drums on the rear. I have the plate and rod from manual brake assembly - my question concerns the Master Cylinder. I was just going to order a non power master cylinder and call it good - then thought I should do a self idiot check and make sure I am not dorking this up. So will this work or am I off base somewhere?
