I did it. Did some notching, drilled two holes and it lined right up. Battery tray is in the stock location. Moved the horns to the opposite side. I even run a clutch fan. The volume of the 26 helps relative to the 22.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
