If you are going with a shortie style header why mess with the center dump style on a stock bodied car? They are designed for a street rod application although I have seen a set on a pick-up truck, 440 engine, that needed just slight notching of the upper frame rail to work. Hedman makes an Elite series header that is routed much better and actually works well on a milder engine combination. The steering coupler that was shown, from what the original manufacturer said, is no longer in production and is currently not available.
To get me out of a jam. Friend has the shorties. No time or money to go searching for headers right now, not for the no budget driverbeater.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
