12 inches isn't that low, chances are good if it's got a cam with much duration it's normal... Adding more base timing may help increase the vacuum & eliminate the bog.. there may be other issues that need looking at but I'd start with checking base timing.... Knowing cam specs would help...
"The Armies of our ancestors were lucky, in that they were not trailed by a second army of pencil pushers."
