8:3 to 1 comp ratio? Something around the 383/440 Magnum cam would be good. Strong midrange power would be best, your choice with the 3.23 or 3.91 gears. With the 3.91's, you could spend a little more money to raise the compression
(heads, pistons) in the motor for more torque/power with the present cam you have. Degreeing ALWAYS helps.
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
