Plugs are standard copper type with recommended replacement at 32k. They will last longer than that but at 60+k its time for plugs. My '06 is coil on plug so wires aren't an issue. Not sure on the '05.
I'd replace the plugs and get the code read - Autozone or others can do it for free. If the code is "misfire" or something like that its probably the plugs.
Dang, Sounds like I'm due to change my plugs in the 03, I'm up to 104,000 miles....
