with stock valve spring pressures, most any conventional oil in the 10w-30 or 10w-40 viscosity ranges with a zinc additive will be fine. Any auto parts store should be able to set you up with a worthwhile additive.
LemonWedge - Street heavy / Strip ready - 11.07 @ 120
