I am looking to put a stroker motor together using a 74 360 block that is currently bored 15 over. I also acquired a set of freshened up 340 X heads. Any suggestions as to what combination to use to get to a 408? I was considering using a 750 Edelbrock Carb and Edelbrock Performer Air Gap Intake. What would be a good cam and piston combination?
Our scat stroker kit would make 408cid if you bore the block .030.
I recommend the eddy 800 carb, much better fuel curve for a performance engine.
I would use the Comp 285HL cam, set the piston about.015 in the hole, chambers at 67cc would net around 9.5:1 compression.
Should make over 400HP unless the heads aren't up to it...
Brian
IMM Engines
Brian Hafliger
