to start with go with the AMD hood with there ring and you need a shaker baseplate with feet and adapter ring with a led of choice get the best bubble and grills to match and a good seal (dont use that jip joint in el paso)then finish later with fresh air door set up ,cable call outs.etc etc. and then
