No stock length H beam rods better tell eagle
http://chucker54.stores.yahoo.net/corodse1.html
Those rods are listed at 6.760...I believe stock length is 6.768. It's only .008 but i went through that when I did my low deck stroker,got some of the last Manleys that are a true 6.768 rod as JohnRR said.
It may be only .008 but it starts to add up once you start adding in other market parts that are shorter than factory , the shorter rod and a piston that is already .020 in the hole is now .028 , if you are trying to build a quench engine you are now .008 further away ....
The Manleys that were available were 6.765 , which is closer but ...
