I did the conversion on a 64 Plymouth. Stock mounts worked and headers from a 66-up B-body fit real well. Found a driveshaft at the junkyard that fit. Check Mancini's site for the SS spring part number as you need new front perches. Trans mount was modified to move the box back 1-1/2" and used the cheaper 68 auto mount.
yeah get w/ Kevin and his dad.... they know their junk.
[IMG]http://i66.tinypic.com/pui5j.jpg[/IMG]
Coming soon!!!!
