I'm sorry that I don't have a picture,but I can describe it. My 67 Barracuda has the springs under the frame rails with full exhaust. I have TTI and use 2 1/2" tail pipes. I don't know about a stock fuel tank because I put in a 15 gal tank in the trunk. The exhaust fits fine. Previuously I has a poly gas tank dropped through the floor and I had only 1/2" clearance between the spings, tank and pipes. If you are using a stock tank, I would not use 3" tail pipes. 3" through the mufflers and 2 1/2 " tail pipes work great.
