Why bypass the ballast resistor..
Running a full 12V without current limiting will smoke the coil pronto..
If you want to run it hotter but still protect it, use the 0.25 Ohm resistor still available from Mopar for use with the Blaster II coil.
Just my $0.02...
The big reson not to run a ballast is to elimate another problem that has lead a bunch of us to have a spare ballast in the truck
It is a easy mod, buy a coil made to run a full 12v then just connect the wires on either end of the ballast.
