Are you saying it's blocked or is it leaking?
To replace it requires pulling the dash back to remove the HVAC box.
If you've never done one before plan on spending 6+ hours doing it.
I was afraid of that , my 2000 cummins Ram is not blowing very cold , the rad is full and it comes up to full temp ... BUT my antifreeze is about 130k since last flush and my thermostat is the original , hoping it's not the core
John, If it's heating up normally, I'd back flush the heater core before replacing it. It's easier and cheaper.
It wouldn't hurt to verify that both heater hoses are getting hot. If only one is it's got a blockage. If both are it could be the temp control door isn't working in the heater box. If a 2000 is like my 2001 the doors are controlled by electric motors/servos.
Kayse can't keep up at all now. lol
