Quote: Think before replacing the fusible links with fuses because the fuses won't be able to deal with the spikes that links will. The starting draw on some of the acessoties is higher than the fuse ratings.
True on the voltage spikes.
I installed a 100a circuit breaker on my dedicated 6ga charging wire. On two occasions it's tripped for no apparent reason.
I rather click it back over than hunt for a fuse, or wire in a new link however.
