Id be more concerned about the 284/484 cam, and the rest of the combo. But id go with the AFB
ditto. I'd think the DP would work fine. If you have tuning issues it's more likely the 484 cam. They like compression, stall and gear. If you are trying to tune a 9:1 318 w/ a stock stall and 3.23 gears you'd be miles ahead swaping the cam out.
[IMG]http://i66.tinypic.com/pui5j.jpg[/IMG]
Coming soon!!!!
