I know you are referring to small block but i have an aluminum flywheel in my 440 tko 600 combo and like it on the street it does take some getting used to but revs quite quickly
Several people have used the phrase "it takes some getting used to", but I wish you could be a bit more specific. Is it just that it revs up (and apparently down) more quickly? I noticed some reference to clutch engagement. I'd be running a hydraulic clutch setup which would tend to soften clutch engagement. Would that make it better or worse? How does it effect launch technique when you want to get to the next stoplight a little quicker than the guy next to you?
Some see the glass as half empty, some see the glass as half full. I just drink straight out of the bottle.
