cause it is suppose to be 12 o'clock ...that is correct...if the cam gear is at 6 ...it is at no. 6 firing...
everyone uses the 6 on cam ..and 12 on crank ...easier to line up...
That's the problem. This engine has not be touched since tear-down, yet at TDC the cam gear timing mark is at 12:00 also. I agree with you but that is not what we have...
BigBlock 74 Swinger
