I ended up grinding a groove in the block. The little bit that I could grind off the starter wouldn't have been enough. Now i just hope I ground out enough. I guess I'll find out once the trans is in.
I mocked the trans up on a different block I had and made some templates to lay out some marks on the engine in the car. So hopefully it's right on. i ground a little extra for good measure
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
