Looks not too bad! Some folding I could not pull out, may be upholstery needed to be filled up a bit - but the seams are where they should be. Took me about 20 minutes to admire it
Just a quick tip to get those wrinkles out if you want to go through the trouble. remove all the hog rings and follow the exact directions from legendary. i think that they say to start at the center and work your way out to the edges and that should pull the right tension to get rid of those wrinkles. It worked for me on my rear seats and there were no problems. Nice job either way. Seat Upholstery is no walk in the park and can be annoying at times. Legendary has online instructions off their website.
