Where is the hole?
Another idea would be to remove a trim strip and cut off a small piece of material from a hidden area.
First glue a slightly larger piece behind the hole by working it through the hole. Let that dry well first,
then fit a patch the exact size of the hole & glue it in place.
If needed, some small dabs of vinyl repair material around the edge should make it nearly in-detectable...
Rick
