Back in the 80's I used the blue regulator that was recommended by Direct Connection, for use with their electronic ignition system. I am guessing this is the same part. It worked fine for many years. I can see why constant voltage could be bad but I am a little confused on this topic. Looks like many of us are. <snip>...
It isn't temp. compensated, and will cut battery life (a LOT) in hot weather.
Rick
