I had purchased a Hurst Comp Shifter and installed it including aligning the shifter linkage...but one evening somehow,someway my trans linkage got kinda stuck in between gears while out on a cruise. I had to take my linkage rods off and adjust the shift tabs back into a gear or neutral if you so desire....put the rods back on and everything was fine again and has been so far.
