I wonder if they didn't errr, and mean distribution block?
yes , they did errr , in 1968 that is a distribution block and its the same part drum OR disc , the proportioning valve is a separate block that is in the line going to the rear brakes .
what year is the disc setup you are switching over to ?
http://www.inlinetube.com/Prop%20Valves/pro_valves.htm
This is where i found it near bottom of the page. I am using complete frt end from 72-74 a-body, k-member(w/spool mounts cuz i keep rippn those damn sandwich type) and lower control arm, upper control arm, spindle and brake assy. Drum brakes really suk under a 446!
SRT8 CHARGER "Four door bore" <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
