I have a 88 dakota with a 318 501 comp cam, 360 heads, weiand intake, the rest is stock parts, .030 cast piston.
Its has about 50lbs. when cold and when warmed up it just above the 0 on the gauge. The rocker are a little loose so the rockers make some noise.
What could be the problem?
