The stock cast iron intakes flow suprisingly well, the only real drawback is weight, they are heavy suckers weighing as much or more than an iron 440 intake! As mentioned above, the Edelebrock LD340 is a good one but I'd skip right to the modern version, the Edelbrock Air Gap. the carb you have is an EXCELLENT carb, should be no worries there with a proper rebuild,
