My 96 Indy Ram was doing the same thing. Try turning the key on and let the fuel pump prime first,if it starts right up,then the pump is weak. I parked mine after work one day a few months back and it wouldn't start. So I poured some fuel in the throttle body,and the the truck started right up. The fuel pump failed. I put a new pump in,and now the truck starts right up in about a half of crank.
70 Charger R/T SE 472 Hemi 70 Charger R/T convertible 70 Charger R/T V Code Sixpack 69 Charger R/T SE Sunroofcar 68 Charger 383 68 Charger 318 71 Charger R/T 70 Challenger convertible 71 Challenger convertible 71 Cuda 340 09 Challenger R/T Classic
